Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - check engine light, p0171 and p1130
View Single Post
Old 01-30-2008, 11:46 PM   #11 (permalink)
vdop69
View vdop69's Photo Gallery
Originally Posted by dc_98_cam View Post
When you let up on your accelerator pedal, the engine vacuum will increase ... If there is a loose vacuum hose, this might be drawing air into the intake venturi ... causing improper combustion ... loss of power. If you get a spray can of starter fluid, you can start the engine, and place a few judicious sprays of ether around the intake manifold, and also any vacuum hose, to try to find a leak, loose hose end, or other problem area.
Thanks for the reply. I was thinking air leak too, however, I had my mechanic check for any leaks and he found none. But I can check again tomorrow.
vdop69 is offline   Reply With Quote
