Originally Posted by suprastuntin
if you've got an irratic idle (up and down) check the AFM. it measures intake air temp. may have something to do with it. the haynes manual has a test that you can perform to check it. if you replace it make sure that it is an AFM from a GT-S, they are different from the other models of the Celica.
I put a wrench in there to hold the little door open and idles fine! now i have a problem with power when driving! i will be checking the afm to see if its bad!!! is it suppose to open ? or what
