Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Smoking 93 LS400
View Single Post
Old 02-05-2008, 08:35 PM   #3 (permalink)
lexusmech
View lexusmech's Photo Gallery
hmm
I'm going with the valve guide seals and/or the idle up valve on the back of the power steering pump. When you turn the steering wheel, pressure drops on that valve to allow a little more air into the motor in order to up the idle when you're sitting. For that, check the two vacuum lines that go to the very front of the intake plenum and make sure they're both dry. If one of them is wet (should be red p/s fluid...maybe....) then thats the valve. It still may not fix the problem, but it would need to be fixed anyhow. Also check (or have checked) the front lower ball joints and the rear trailing arms.
Better yet, take it to a dealer, pay an hour diagnosis and find out whats really wrong with it before you go throwing money around.
90' ES two-fity, balanced motor, head work, home built intake, lowered, wheels, window tint and some stereo upgrades, next...building my headers.
lexusmech is offline   Reply With Quote
