Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - 22re High Idle
Thread: 22re High Idle
View Single Post
Old 02-07-2008, 07:56 PM   #2 (permalink)
digmycelica
View digmycelica's Photo Gallery
Check to make sure the throttle cable has a little slack in it. it might be too tight which will do what you are saying. it requires 2 12mm open-end wrenches to adjust it under the hood on the throttle body. If not , then try turning the air screw on top of the throttle body clockwise . if this helps then put a dab of silicone on it to keep it from vibrating back out.
digmycelica is offline   Reply With Quote
