So the saga continues.
Not nearly as bad as before though first day no problems not a sign of surge or drop in idle but today I was driving and it began to feel like a miss every once in awhile I have brand new plugs perhaps I will recheck the gap on them.
I no the repair yesterday near the EGR is taken care of and thourghly insulated.
And the problem is not quite the same.
Seems the computer relearns a problem but gives no codes.
I'll check the Grounds see if there are any issues. Any guesses out there.
It does not miss in idle only under load, so I step on the brake and rev it up 2k and cannot get it to repeat.
Idles perfect in drive and in park do you think
maybe a bad plug , o2 sensors put out codes right ?
And the timinig off by the thinnes of a dime does that matter.
would I see more problems if the timing was off.
Thanks Tom
Reason: not the solution
