Re: 22re High Idle
Hmm, interesting that you noticed it was worse in cold weather. I was thinking that my car was running better over the past couple days, which coincides nicely with a warm streak.
I've searched a few forums and this seems to be a somewhat common problem, but I haven't seen any posts that indicate a definitive fix. Either 1) people don't post after they solve the problem, or 2) the potential cures are worse than the disease.
Anyway- I can verify it isn't the throttle cable. I had it dissassembled and cleaned once, and I checked it again after digmycelica's post- there is enough slack. Reposting from another thread on a similar/same problem, somebody recommended checking (in order): A) AFM, B) Throttle Position Sensor, and C) Idle Air Control (if present).
I don't know how to do any of that, and didn't find it in a cursory look through the repair manual I have (Chilton) but I'm not a very good mechanic, either.
