tC is an E350 transmission, Corolla XRS and Camry are E351 transmissions. That being said it seems that the Corolla has some changes compared to the Camry, as the fluid spec is SAE 75W GL-4 unigrade gear oil while the Camry/tC call for 75W90 GL-4 or GL-5 gear oil.
The other thing, and I don't think this is the case on the 07-09 Camry E351, is that Toyota does not have an interval to change the gear oil for the manual transmission in the 2009 Corolla. The transmission is only to be inspected for leaks. This is the same for the automatic transmission which of course uses Toyota's WS ATF.
Also the final drive ratio on the Camry is 3.95:1 while the Corolla is 4.24:1. The final drive combined with the lighter weight should result in the Corolla XRS feeling noticeably "peppier" than the Camry, especially off the line, though it will of course result in higher revs on the highway.
2011 Lexus IS250 Obsidian "F-Sport 6MT" with LSD
1986 AE86 Corolla GT-S Supercharged
