Do not have the data on this model.
Check the following fuses (if you have them): Dome, Cig/Radio, ECU-IG, Stop.
You can bypass the shift lock. Look on the shift console near the shifter for a small tab, cover or slot. Remove the tab or cover and use a small blade screwdriver to push down on the plastic tab. When pushed down shift out of park. You can then operate the trans but will need to repeat this process each you want to move the selector out of park.
The shift lock has an electric solenoid lock. The brake pedal needs to be pushed (hence checking the brake fuse) and key on for it to operate. Depending on the car it may receive power from the Cig/Radio, ECU-IG and Stop fuses. Check your stop lights to see if they work.
Most likey you also blow another fuse. The radio usually has two fuses, Dome and Cig/Radio or something like Radio on the name.
And make sure you have found all the fuse boxes, Toyota spreads them around,may have one under the dash drivers side.
