Well tell you what! as i was test driving to see if i have fixed the power problem couple of bolts came out well i turned around and went home! and i jacked up the car and i see that there the engine mount bolts!!! also the support member going from gas tank to front wasnt bolted on! after i put the 2 bolts were they needed to go plus that other bolt!!! it had way more toque!
nOW I timed it to 10Degrees! as it should be ~! but my rpms are high 1300rpm plus its really RICH!!!!! How can i adjust the fuel amount! Or is there a way to reset it!
