Originally Posted by 95PimpingCamry
If you look around in the right places you might be able to find some cheaper flex pipes, most likely universal and not application specific. Either way i would definitely recommend NOT having Monro do the work. From past experiences that my friends have had with them they do the worst welds and will cut corners anywhere possible, even if that means that their work won't hold up. I've seen them hang exhaust pipes with self tapping screws into a heat shield, and I have never seen any of their welds that didn't leak. Over all you'll spend more money correcting Monro's mistakes than you would to have it done right in the first place.
They did such a horrible job, the wields look like the person did it their first time. It still leaks exhaust, the same amount before but now in two spots. Also when I tried to open my hood, they broke the hood latch. I could fix it, but I want them to do it.
