Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Flex Pipe and Mechanic Problems
View Single Post
Old 02-18-2008, 08:10 AM   #6 (permalink)
bronzemaxell
bronzemaxell's Avatar
Gameroom cash: $270860
View bronzemaxell's Photo Gallery
i just spent around $150 shipped for a new aftermarket 97 4cyl flex pipe with cat and gaskets on eGay, jacked up the car, use a long extension, and unbolt the front 3 nuts easily from the bottom of the car, the two bolts after the cat is a little tough, one of them is around, i used a dremel and re-enforeced disc and cut the bolt off. took me about 30 minutes. good fitment, new cat, works like new, and don't have to worry about the gasket after the cat leak either. i did called around muffler shops, they wanted around outrage $150 to $180 + tax to cut and weld as well.
bronzemaxell is offline   Reply With Quote
