Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Changing Brakes '07 Camry
View Single Post
Old 02-18-2008, 11:30 PM   #13 (permalink)
TRD VVTi
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Originally Posted by w203 View Post
how reputable is your source on this?
you brake lightly so you use less pad material, you brake harder so you use more brake material from the front. more pad material from the front....
brake bias always have more force going to the front of the vehicle in most if not all passenger cars, regardless of lighting braking or heavy braking
That's not true. A proportioning valve will have greater effect under higher pressures.
It takes less force/pressure to move a smaller object/displace a smaller amount of brake fluid.
2006 Camry LE Special Edition
