Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - factory sat. radio.
View Single Post
Old 02-19-2008, 06:34 AM   #5 (permalink)
EuroPlate
Polish Pleasure Member
View EuroPlate's Photo Gallery
I took it apart a month ago when installing a Sirius kit...
Hopefully this will help you...
In step 5...remember to pull up from the back (edge closest to the armrest) as the front has little hinges...
Here are a few pics from the install:
This is the SoundLinQ2 kits...
Here's the center console almost completely removed...
Head unit removed...
I ran the antenna wire through the trunk under the rear seat...
Trunk...
From the rear seat I ran the wire under the plastic molding...
From here I ran the wire under the carpeting and driver seat...
I used two plastic shirt collar inserts to insert the wire behind the rubber molding that's around the back windshield...
I also hid the Sirius antenna with a VG Shark fin, you can see more pics and info here...
I installed the SoundLinQ2 and Sirius tuner on the passenger side under the airbag (there is enough room there so that it stays out of the way of the airbag and it keeps the tuner static free since it's not near the head unit)...
I mounted the two units using double side heavy duty 3M tape (keeps everything on solid and no vibrations)...
Here's everything back together...
2007 Camry SE V6 - Titanium Metallic w/ Dark Charcoal - JBL Audio - Sunroof - Rear Spoiler - Auto Dimming Mirror w/ Homelink - 30% LLumar Tint - VG Shark Fin - SoundLinQ2 Sirius Kit
I AM THE STIG
EuroPlate is offline   Reply With Quote
