Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - 2002 Camry v6 "Chug" Problem...help?
View Single Post
Old 02-19-2008, 01:54 PM   #5 (permalink)
marc780
View marc780's Photo Gallery
Did you get the tiiming belt changed recently? If so then the mechanic screwed up the install and needs to reinstall the belt.
Other things that might cause this:
-timing belt worn and stretched, has skipped a couple of teeth i.e. it has jumped time
-timing belt tensioner worn out and not applying pressure to idler, and timing belt is too loose and has jumped time because of that
-One or more injectors clogged or dead (i had this happen on another car and it also idled poorly too, but did not even throw a code)
-weak fuel pump (but usually a fuel pump just quits working and does not do a slow fade)
-one or more spark plugs not firing (but usually this would make the CEL blink on)
-one or more dead coil packs (the big plastic and rubber thing that fits over the spark plug)
-low engine compression and needs a valve job or more
-a transmission issue
