No need to splice and dice. Go to Radioshack and purchase a couple of T-taps for 18-22 gauge. The T-taps look like these,
http://images.google.com/images?q=t-...=1&sa=N&tab=wi
Then just buy some 18-22 gauge red and white wires (or color of your preference) and use the T-taps to connect the existing wires with the additional wires. As for buying the right switch, someone else might want to chime in on that. Good luck.
Originally Posted by KevinsCamry
I thought of a new switch but wouldn't know which wire to connect to which post of the new switch. Unless you cut and splice into the white and red wire to make them longer you will have to make those connections under the dashboard somewhere. If the switch is in the dash then the red and white wires will not be long enough to reach the engine compartment.
I'm not good at all when it comes to automotive electric.
