St215 (caldina Gt-t) 3sgte into a St185 Celcia, Vacuum Lines help - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Division and International Models Forums > International Model Forum > Caldina Forum
Caldina Forum Discussion area for all generations or the Toyota Caldina
Old 08-14-2011, 08:10 PM   #1 (permalink)
View 90CelicaGt4's Photo Gallery
Australia St215 (caldina Gt-t) 3sgte into a St185 Celcia, Vacuum Lines help
Hi Everyone,
New to this forum, Hoping someone can help with this. So I have put a St215 3sgte into a St185 celica Gt4 and i have these two vacuum lines open. Does anyone know what i need to do?
The engine currently will run for about 1 minute and then it will slowly fade off and stall (revs will drop). I'm thinking it maybe these lines open?
By the way these ends are just under the throtle body
Please help
90CelicaGt4 is offline   Reply With Quote
Old 08-14-2011, 09:40 PM   #2 (permalink)
Full Throttle
Kiwi-Corolla's Avatar
Gameroom cash: $954115
iTrader Score: 16 reviews
Welcome to Toyota Nation! I just had a look at my brother's GT-T and from what I can tell, the larger hose goes to the airbox and the smaller hose goes to the factory BOV. His hoses have been blocked off because he's running an aftermarket BOV and a custom cold air intake, but that's where they led to previously.
Old 08-26-2011, 02:29 AM   #3 (permalink)
View caldinamad's Photo Gallery
about blocking them up will the car stall
caldinamad is offline   Reply With Quote
Old 08-26-2011, 02:32 AM   #4 (permalink)
Full Throttle
Yes, sorry, was meaning that his hoses have had a screen placed over the ends of them so that it can still breathe but can't suck in foreign objects.
The Following User Says Thank You to Kiwi-Corolla For This Useful Post:
caldinamad (08-26-2011)
Old 08-26-2011, 03:11 AM   #5 (permalink)
ooh so u guys done that to both of them did you use mini filter?? and the one that was suckin the air from the standed bov in the air box what did you do with that
Old 08-26-2011, 03:19 AM   #6 (permalink)
Full Throttle
We were going to use a mini filter but it was cheaper just to use a stocking and tie it on with a cable tie . From memory we did that with the two larger hoses, but used the line for the original BOV as the vacuum line for the aftermarket Blitz BOV
Old 08-26-2011, 03:30 AM   #7 (permalink)
you are the man!!!!!!!!!! and so the pipe off the intercooler is the one you used eh . and thankyou for being active mate.m\My intakes 3 inches the hole way and has a tube off the elbow to put one off thoz vacume hoses on it hahahahah shoda just done what you did eh with the stocking just maby it myt suck it up hahahah
Old 08-26-2011, 03:51 AM   #8 (permalink)
Full Throttle
No problem mate. Don't use the nipple on your CAI piping as your vacuum source. Make sure you use the original BOV vacuum line.
Here's a pic of which hoses are which - The only one you need to connect is the BOV vacuum line to your aftermarket BOV:
Old 08-26-2011, 04:47 AM   #9 (permalink)
the one you your pointing to is the big hose eh that went to the bov not the the lil one in front eh the bigest hose that went to the standed bov
