Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - 91 mr2 fuel cut, just installed boost controller
View Single Post
Old 03-14-2008, 06:57 AM   #9 (permalink)
4DMR2t
FRANK THE TANK LIVES!
4DMR2t's Avatar
View 4DMR2t's Photo Gallery
Originally Posted by ModifierMR View Post
Doesnt the boost pressure sensor do other functions besides just fuel cut? Wouldnt that be imperetive to letting the ECU know how much fuel to add.... beacuse when a turbo boosts it creates a lean condition and you need more fuel... if the engine sees no boost then you could run super lean.
The boost pressure sensor doesn't factor into how much fuel the ecu adds. It simply sends a signal to the ecu to control fuel cut and the factory boost gauge. When the ecu sees 5 volts coming from the sensor, it initiates fuel cut.
When u mash the throttle and u get boost, the ecu dumps added fuel to keep the engine from running lean. This is controlled by the throttle position sensor. When the ecu sees wot, it adds fuel additional fuel, which makes it run pretty rich, but safe from going boom!
I use the vacuum line that originally ran to the boost pressure sensor for my Omari gauge. It eliminates fuel cut, and provides a free/clean line for my gauge.
"It's hard to drive at your limit, but it's harder to know where it is." -Sterling Moss
4DMR2t is offline   Reply With Quote
