Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Airbag Sensor (underneath hood)
View Single Post
Old 03-24-2008, 11:38 AM   #3 (permalink)
JSM1284
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $187325
View JSM1284's Photo Gallery
Front Right SensorAir Bag Front RH Sensor
REPLACEMENT
  1. PRECAUTION Observe Air Bag Systems; Service Precautions.
  2. DISCONNECT BATTERY NEGATIVE TERMINAL
  3. REMOVE ENGINE UNDER COVER RH
  4. REMOVE AIR BAG FRONT RH SENSOR
  1. Remove the bolt and front airbag sensor RH.
  1. Disconnect the connector from the front airbag sensor RH. HINT: Insert a screw driver in any of the three opening sections of the sensor and slide the sensor to disconnect it from the connector.
    1. INSPECT AIR BAG FRONT RH SENSOR
    2. INSTALL AIR BAG FRONT RH SENSOR
      1. Check that the ignition switch turn OFF.
      2. Check that the battery negative (-) terminal is disconnected. NOTE: Do not start the operation for 90 seconds after removing the terminal.
      3. Install the front airbag sensor RH with the bolt. Torque: 17.5 N.m (178 kgf.cm, 13 ft.lbf)
      4. Connect the connector to the front airbag sensor RH.
      5. Check that no play is identified.
    1. INSPECT SRS WARNING LIGHT
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
