Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Replacing Rod bearings ...
View Single Post
Old 03-25-2008, 01:10 AM   #2 (permalink)
toyomoho
View toyomoho's Photo Gallery
There should be a number on the cap: 1, 2 or 3 for the thickness. Given your info assume it is a 1.
Standard rod clearance is 0.0009-0.0022 inch. Max clearance is 0.0031.
A standard after market bearing should provide this clearance range but best to confirm using a Plastigage. Have used both the sized bearings from the dealer and standard aftermarket bearings to replace them with no problems. Just make sure you are in the clearance range.
