Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - 2009 Camry: V6 TRANS "FLARE" Fixed?
View Single Post
Old 03-25-2008, 08:57 PM   #15 (permalink)
geoff5093
geoff5093's Avatar
View geoff5093's Photo Gallery
Originally Posted by thoots View Post
I'm nearing 2,000 miles on my 2008 V6 SE -- 10/2007 build date. The transmission has been 100%, absolutely PERFECT.
Originally Posted by niceguy View Post
Mine was built on Jan 2008. ODO shows 1130 miles. The engine has been perfect so far. Maybe it is too early to tell.
Originally Posted by Streaker View Post
2,000 mi. on my second replacement and so far no flare. "Knock Wood"
I'm not sure about you guys, but since we all live in the northern states where it gets pretty cold in the winter, I've never had a single flare occur when the car was cold. I believe it's because of the cold that the transmission holds 3rd gear much longer then it does when it's warmer out, which is basically what the TSB fix is suppose to do.
Wait until late spring/summer when the temps start getting 60F+ in the morning, and you may start seeing the flare more often.
geoff5093 is offline   Reply With Quote
