Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Replacing Rod bearings ...
View Single Post
Old 03-28-2008, 12:30 PM   #5 (permalink)
ohgood
ohgood's Avatar
View ohgood's Photo Gallery
Originally Posted by Hajoca View Post
The torque procedure should be followed, the fasteners are designed to be stretched a bit, to overcome the repeated tension/compression stress cycles. How much further (in degrees) like 2 degrees? How much did you add?
If you turn too much, you will over stretch the fastener, and then the fastener will yield, and the fastener and joint will not be at the designed tension.
I like the way you talk. (from the movie Swing Blade)
Good information too. Thanks.
ohgood is offline   Reply With Quote
