Not up on this specific axle but in most cases the outer joint is permanently attached to the axle.
Call around to machine shops or dealers to determine if they have a die that can be used to reform the threads. This would be the easiest approach. Remember the treads are metric.
To take the axle apart as far as you can you will need to remove the inner boot. Once off, there is typically a clip inside the inner CV joint housing that prevents the joint from pulling apart. If so, remove this and the joint will come apart. Once apart there normally is another clip holding the rest of the joint that is still attached to the axle.
Another alternative is to also remove the outer boot leaving only the outer joint and bare axle. A good machine shop should have a lathe large enough that the axle will slide into the hollow spindle of the lathe and then the CV joint can be chucked for turning. Wrap the exposed part of the joint with something like thin food plastic wrap to keep out any debris, this should not effect the cutting operation.
You will need to install new CV boot bands when reinstalling the boots.
Worse case shop around for an axle, you should be able to find one for about 1/3 of the cost of a dealer.
