It has the satellite receiver wiring (AVC-LAN bus to the Headunit) and satellite antenna wiring installed. Both connectors are located behind the righthand trunk liner. XM (part #'s 86180-0W031 and PT546-02080) or Sirius (part #'s PT54500080 and PT54502090) are required. Each set-up requires the receiver and fit kit. I guess that the pre-installed wiring was originally for XM because the SIRIUS installation does not use the factory installed antenna (the kit has a seperate antenna which is installed on the trunk lid). I would assume that the antenna connectors are not compatible between the two systems (there may be an aftermarket solution).
