Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - headlights
Thread: headlights
View Single Post
Old 04-09-2008, 07:34 AM   #5 (permalink)
Gramps 750
View Gramps 750's Photo Gallery
On the turn signals (this is going to sound strange)take the bulb out of the socket and look into the socket, you will see 2 silver tabs CAREFULLY with a tooth pick pull up on each tab so that they make a better contact to the bulb.
As far as your headlite problem I bet that both bulbs are bad on the low beam side. Common problem, what happens is 1 bulb goes and sends a power serge and blows the other. Pull the bulbs out and with a test lite check and see if you have power as you go back inforth from low beams to high beams.
Gramps 750 is offline   Reply With Quote
