Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Roughness around 2K RPM...
View Single Post
Old 04-23-2008, 09:09 PM   #1 (permalink)
mytoy
View mytoy's Photo Gallery
My 96 4cyl Camry has 155k miles, fully maintained car since new. Recently it
seems to have a roughness around 2k rpm. The roughness can be felt when
driving(2k rpm or abouts). Mostly felt if cruising, feathering the gas in that range. If you accelerating through that range it feels fine. Power is about as usual, no noticable loss of power. I use Sunoco-89 all the time. Recently had some servicing done...Timing Belt, Dist Cap&Rotor, PCV, Ignition Wires, Plugs, Water Pump, Cam Shaft Seal, Oil Pump Seal, Main Bearing Seal, Fuel Filter, Air Filter.
Any thoughts on why this rougnhness? Repair center that did the above work is at a loss as to why the roughness.
Appreciate comments...
mytoy is offline   Reply With Quote
