Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - wheel bearings
Thread: wheel bearings
View Single Post
Old 05-06-2008, 04:21 PM   #2 (permalink)
BamZipPow
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $869010
View BamZipPow's Photo Gallery
Originally Posted by manny530 View Post
do the wheel bearings have to be pressed into the hub
whats the difference between inner an outer bearings.
Also i destroyed the 54mm nuts that hold the hub in is this a part i can buy from a parts store if so what do i ask for?
No...the bearing don't have to be pressed in. The bearing races can be tapped out and carefully tapped in using the right tool...don't use a screwdriver!
The inner bearing (bigger diameter) is the one that rides closest to the inner part of the spindle while the outer bearing is usually the much smaller set and rides to the outer part of the spindle..
Not sure if you can git them there but you should be able to git them from a parts recycling place...
BamZipPow is offline   Reply With Quote
