i just replaced the lines on my camry. camrys dont have disconnect lines, they only have 14mm lines threaded to 19mm. and you are correct about the number of lines, 2 to the top of the tank and 1 to the rear. they are fairly easy to disconnect assuming there isnt any rust. pull your back seat and open the access panel to the top of the tank and take a look. i would think leaky fuel lines dont leak more depending on the angle of the car when parked. the filler neck and seal for the fuel pump do.
