Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - es 300 won't start
View Single Post
Old 05-11-2008, 11:34 AM   #5 (permalink)
wonger
wonger's Avatar
View wonger's Photo Gallery
Originally Posted by aridlc View Post
well the short problem is something i will have to look into but I really think that it may be giving faulty codes. my car will turn over but not start. i did get it to start one time today and it ran and idled fine for about 5 min then just shut off. i checked the fuel filter by unplugging the top fuel line and turning the car over but no fuel came out. I removed the fuel filter and could easily blow through it. I then watched to see if any fuel would come out of the fuel line while turning the car over but no fuel came out. does this mean i have a bad fuel pump. can i jump it out and see if it works? I sprayed starter fluid in the intake while it was been cranked and it would start momentarily.
from this.. it might be a fuel pump.. but i would look at the fuel pump relay 1st.. it wont be lable as a fuel pump relay.. but its called a Circuit Opening Relay ( CIR OPN ) you can try to swap it with other one that looks the same
88 4Runner
wonger is offline   Reply With Quote
