Well I found it after 5 days of cleaning iac valve, maf sensor, checking fuel pump/filter, fuses, I found it...someone on a lexus site told me to check the pcv valve and there it was. As I was trying to pull out the pcv valve I bumped a ground wire connected to the throttle body and it moved..loose nut on that little sh**. Tightened now she purrs like a kitten again...Now for some reason while doing all of this my ABS light came on and now I can't automatically shift into gear. Also my speedometer does not work. Code comes up speed sensor malfunction. I did change around some of the relays in the fuse/relay box under the hood so now the search is on......rrrrrrrrrrrr does it ever end?
