Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - es 300 won't start
View Single Post
Old 05-11-2008, 11:07 PM   #7 (permalink)
wonger
wonger's Avatar
View wonger's Photo Gallery
Originally Posted by aridlc View Post
Well I found it after 5 days of cleaning iac valve, maf sensor, checking fuel pump/filter, fuses, I found it...someone on a lexus site told me to check the pcv valve and there it was. As I was trying to pull out the pcv valve I bumped a ground wire connected to the throttle body and it moved..loose nut on that little sh**. Tightened now she purrs like a kitten again...Now for some reason while doing all of this my ABS light came on and now I can't automatically shift into gear. Also my speedometer does not work. Code comes up speed sensor malfunction. I did change around some of the relays in the fuse/relay box under the hood so now the search is on......rrrrrrrrrrrr does it ever end?
know how u feel.. my accord i had for so many years now with just oil changes and rotates.. within the last 6 months i have replaced alot of stuff thats been wrong. but feels good when its all done. knowing that its all fixed
the speed sensor might be bad. but i would pull it out and see if it has any metals stuck to it.
i also know new cars dont have a vehicle speed sensor in the transmission anymore.. they use readings from all 4 wheel speed sensors to put up the speed on your speedometer
88 4Runner
wonger is offline   Reply With Quote
