You didn't mention weather you have a 3.0 or a 3.4, but it does not matter any way. You should be able to just pull the crank pulley off with your hands, be careful if you deside to start prying, as the cover is made of plastic. Anytime you get into the front that far, I would replace the front seal and Waterpump. How much is you time worth? What if you have to go back in a short time later? You should also replace the idlers and tensioner at the same time. If you have A/C, the tensioner bearings are available from a bearing house, and will cost you around $10.00, as apposed to $40.00 for the A/C idler.
