Airbag Sensor
Getting closer ... I see what you are talking about regarding the Seatbelt Pretensioner ... not sure how all this fits together so going to ask some novice questions.
Wiring is fine ... tested continuity.
Which airbag sensor are you referring to ... i know there are several sensors in front of vehicle ...
Is there a particular sensor that runs ... from computer (main) thru sensor to pretensioner ... or are you talking about the sensor that is in the pretensioner ...
I assume i can get parts from junk yard ... if for example, the vehicle had rear collision ...
I also assume i will need special equipment to clear the codes from SRS System ...
