hello there corrosion has been causing these lower control arm bushing to rust and come apart they are not made with very good steel.I am a mechanic and we have manufactured a replacement bushing that any mechanic can put in for a fraction of the cost as replacing the whole control arm.The bushing can be purchased for about $58.00 from us and then you should be able to have a mechanic put it in for about an hour or two worth of labor.This would save you a lot of money i know the control arms are expensive i have pictures we took of a bushing we installed in a 99 sienna these bushing will fit 98-03 model years they may even fit other models too we are still researching this.The bushing are made of stronger steel and rubber then the factory ones. i have pictures of the old bushing too so you can actually see the difference of the two.
