Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Front Lip problem. Need ur input.
View Single Post
Old 05-24-2008, 02:23 PM   #15 (permalink)
Own
View Own's Photo Gallery
Originally Posted by CheapChic View Post
The clip is broken.
there is a black urethane caulk that BMW uses, it called Betalink.
it is thick, I would use that
Hmm. Ill do some research on it and see if i can get it. So far its 3m tape/screw. May be betalink too.
Originally Posted by Rapid Roy View Post
If you get the 3M auto body moulding tape it will be permanent. Just make sure both surfaces are clean and dry. Your emblems and body moulding is held on with that stuff.
Originally Posted by TRD VVTi View Post
+1
The real 3M stuff works fantastic. It's amazing how well it holds and how much pressure it can take. Make sure it's not the white stuff. The grey tape is what you want.
Is it good in High temperatures? Ill buy 3m tape today. Hopefully it available in canadian tire or home depot. Plus ill figure out what to do with screw. Decided to move installation for tomorrow morning.
TY
Own is offline   Reply With Quote
