Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Post engine-swap/transmission rebuild problems
View Single Post
Old 05-26-2008, 04:10 PM   #11 (permalink)
Maim Menu
DIY : I believe
Maim Menu's Avatar
View Maim Menu's Photo Gallery
Well, the P0446 popping up alone is usually the VSV located on the charcoal canister at the back of the car. It might be defective (unlikely since it not even near the engine, so can't really be damaged during a swap) or registering a bad signal because of the 3SFE swap, wich is more likely.
But before even thinking of fixing that, you should have a proper 5s-fe or 1MZ-fe dropped back in there, cause you're getting robbed my friend.
Restoring '65 Chevy Impala Super Sport w/ 327-300 small block, Edelbrock carb/intake and T-5 tranny that will probably blow up.
Black '98 Camry LE 4Cyl Auto, 188 000Kms and counting
Black '98 Camry CE 4Cyl Auto, 295 000Kms and counting - SOLD
Maim Menu is offline   Reply With Quote
