Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Leaking fuel filter
View Single Post
Old 06-13-2008, 01:11 PM   #11 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
If you were able to reinstall the original filter with no leak and the replacement filter leaks then there must be a problem with the replacement filter. Obviously, your installation technique must be OK since you successfully remounted the original filter. Something with the replacement filter is different than the original. It almost sounds like the replacement has a different angle for the flare or it has a scratch on the mating surface. Either they should give you a filter that fits or refund the cost.
Kep
