Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Hungry Car
Thread: Hungry Car
View Single Post
Old 06-13-2008, 01:16 PM   #6 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
If you get the coolant to leak under pressure you should be able to track down the leak. You may need to add a UV dye to find it. If it isn't coming out in the oil or exhaust I believe that it will be visible.
By the way, you said that you topped it off. Has it dropped down again? How much in how many miles?
Kep
