Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - 93 tercel
Thread: 93 tercel
View Single Post
Old 12-08-2003, 05:25 PM   #2 (permalink)
Tercel GTS
N/A bites
Tercel GTS's Avatar
Open the hood and stand beside the driver's fender, look where the engine and transmission fit together, now look just behind the engine. The starter is right there. The bolts are on the transmission side, facing you as you stand there. A 14mm socket fits them, a 12mm takes the battery wire off, and a small wire is clipped on. Takes 5 minutes to remove if you do it often, no more than 30 minutes first time ever.
雄のハヤブサ
Tercel GTS is online now   Reply With Quote
