Is it when you move the actual shifter, or when you clutch in or out?
If it's when you move the shifter, you probably have a bad bushing, or the joint the shifter pivots on may need lubricating. Usually when the synchros in the transmission start going out, you will hear grinding noises and/or the car will not want to go into gear.
If it's more when you clutch in or out, especially when you dump the clutch or just stay in the gas a little as you clutch in or out, you might have a motor/transmission mount issue.
'96 4cyl 5spd Camry
147k miles and running out of things to fix...
