Originally Posted by O.V.N.
I don't know...
I had the same problem this week. Replaced the A/C Relay with "A/C Relay Fctry" from Advance Auto Parts for $14.
But it doesn't seem to fix the problem.
The A/C will go full blast for a while, but then the "green flashing death light" starts in again.
Did I get a bum part, or is there possibly some other problem?
(P.S. I already replaced the air filter).
I would try another relay before moving on to any of the other mentioned possibilities. A quick and cheap way to find out if it's the new part you got that's bad or something else is to take out the High Beams relay and place it in the spot for the mag clutch relay. Drive around for a while and see how your a/c performs. If the light doesn't begin to blink as it has been, then you just got a bad part from Advance. If it does, then the problem is somewhere else.
