Originally Posted by slick07LE
I would try another relay before moving on to any of the other mentioned possibilities. A quick and cheap way to find out if it's the new part you got that's bad or something else is to take out the High Beams relay and place it in the spot for the mag clutch relay. Drive around for a while and see how your a/c performs. If the light doesn't begin to blink as it has been, then you just got a bad part from Advance. If it does, then the problem is somewhere else.
Thanks for the tip. Any idea where the high beams relay is, in relation to the A/C relay?
Thanks again.
