Originally Posted by Twix
To replace that seal you need to take the engine out, and then to take out the gearbox and torque converter...when you remove torque converter you will see that seal (it is about ~4cm in diameter in the center of gearbox where torque converter is getting in)...
Try looking on this forum for some pictures if someone already did it...
And you can check here for more about automatic gearbox (useful to read) : http://www.familycar.com/transmission.htm
So how many hours would you estimate it to take to do this repair? I'm not a mechanic so I would need to pay someone by the hour to do this and I need to figure out an estimated cost.
Thanks!
