Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - 1992 camry water on floorboards
View Single Post
Old 07-16-2008, 10:00 PM   #12 (permalink)
1996camry
View 1996camry's Photo Gallery
make sure the back seat dry...if a good Sunny day, lets the window down to get the air circulate inside your car..and allow the sun to expose the spot that was wet back seat...Make sure all the wets spot dry out because you don't want mold built up inside your car....
Everything dry, then I would do the water hose test to see if water get inside your car or not...
Also, I SUGGEST JACK THE CAR UP WITH GOOD SUPPORT AND GET UNDER NEED YOUR CAR TO SEE CRACKS HOLD THAT WATER CAN GET INSIDE YOUR CAR...
TRY THAT AND POST BACK WHAT YOU FIND...MAKE SURE THE WET SPOTS DRY OUT....LETS THE WINDOW DOWN SO AIR CIRCULATE INSIDE YOUR CAR...LETS NATURE HELP YOU OUT (DRY) WET SPOTS..
1996camry is offline   Reply With Quote
