Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - 01 rough idle, car stalls
View Single Post
Old 07-22-2008, 01:14 PM   #2 (permalink)
doc1976
View doc1976's Photo Gallery
Sounds like the cat may be plugged.
"Sometimes you can tell that a converter is clogged because you don't go any faster when you push the gas pedal. Also, there usually is a noticeable drop in gas mileage associated with a clogged catalytic converter. A partially clogged converter often acts like an engine governor, limiting the actual RPMs to a fast idle. A totally clogged converter causes the engine to quit after a few minutes because of all the increased exhaust back pressure.
The catalytic converter, like the rest of the emissions system, typically has a warranty length that exceeds the term of the warranty for the rest of a typical U.S. automobile."
doc1976 is offline   Reply With Quote
