Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - P1135 and P0125 code
View Single Post
Old 07-29-2008, 12:08 PM   #12 (permalink)
hsdad
View hsdad's Photo Gallery
Originally Posted by deanus View Post
Thanks for your help, I'll let you know how I fair.
deanus,
sorry that I have been away from the board for awhile.
Let me provide an update.
Recap.
I originally coded as a P1135 (Bank 2, Sensor 1). That was happy news because that sensor can be changed without any stress with a basic 7/8 open-end wrench.
after spending 207.00 for the sensor at the Toyota Dealer (I believe a Danzo/OEM may be around 180.00), putting it in, my check engine code changed from P1135 to the 'infamous' P1155 ...the evil back side/Bank 1 (Bank 1 relates to the side with cylinder no.1).
For me to succeed in getting the wiring connector disconnected and removing the sensor I ended up removing the passenger side front tire/wheel AND removing the Tie Rod End to allow me to move the tie rod out of the way so that my arm could reach into the space to release the connector and operate a standard open-end wrench.
Note: there may be contortionists with little spaghetti arms that could do this without removal of the tie rod end but I am not one of them. Also, I studied the connector operation on the side I could easily approach to gain confidence of how to operate this 'by feel' at the end of my right-arm's reach (unless you are a masochist, a 'cool' exhaust pipe is a must ).
I used a VOM set to read resistance measurement (ohms) and checked the resistance across the two pins that are connected to the sensor by black wires (this is the heater element portion of this 4-wire sensor). Sure enough, the reading indicated an 'open' circuit ---very high resistance in the Megohm range of digital meter.
the new sensor AND the one I removed from the Bank 2 side, both read somewhere around (or below) 20 ohms (it's been awhile, sorry for not having the exact value). I regret not being as confident and well-informed to qualify a living or dead sensor before I changed out the front/Bank 2 sensor but silly me...I trusted a specific code.
I put my recently removed sensor from Bank 2, back into the Bank 1 location, and then ran the car. IT TOOK MUCH LONGER THAN I ORIGINALLY THOUGHT IT WOULD for the check engine light to clear.....but it did clear (somewhere between 10-50 miles of driving consistently 50 mph or greater).
the good news...
I compared the two sensors for physical attributes, they are virtually identical with the exception of a slight difference in the length of the wiring between the sensor and the connector. I think the bank 2 (front/radiator side sensor) had a slightly longer pigtail then the Bank 1 BUT I AM NOT POSITIVE which one was longer. I mention this because when I went to the Toyota parts department, they list the Bank 1 and Bank 2 AF heated sensor as two different part numbers.
I hope that some can benefit from my suffering.
Just some basic facts:
Sensor failed (confirmed by heater circuit reading OPEN) at around 94K miles; Sienna 2002 XLE
hsdad is offline   Reply With Quote
