Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - How to remove antenna housing.
View Single Post
Old 07-30-2008, 01:57 PM   #2 (permalink)
EazyE17
View EazyE17's Photo Gallery
I figured it out
In case anybody else has this issue: You remove inside cover from behind the right rear tail light. You can disconnect the wire just by pulling it loose. There was a little tape around mine. Then you can pull the antenna down which leaves just a hole. I purchased a new antenna from an auto parts store by my house for $10. All there was to do was plug the new antenna into where old one was pulled out and screw it on. A very easy fix.
EazyE17 is offline   Reply With Quote
