Originally Posted by cabur
There is no remote release.
I had to remove the trunk inner liner when I was installing the back-up sensor. All that's opening the fuel cap door is a cable and sleeve as in bicycle brabe cable.
If you really have a cable failure guess you have to remove the left trunk liner and pull at the cable. Liner is quite easy and straightforward to remove.
I figured as much after scouring the car and the manual. Thanks for the heads up.
BTW, I have broken many of those type plastic fasteners that hold the liner in, on other cars...
Is there a trick to getting them out so in case you need to change a blub or heaven forbid, free the gas door....?
Still love the car though.
