its a fairly easy install....do a quick search and there might be a DIY on it around here
to my knowlege all you need is a 12mm socket for the sway bar mount bolts (3 on each side) and a 14mm wrench for the sway bar links (1 on each side), and a set of allen wrenches in case the sway bar link bolt decides to twist with the nut...
be sure to remove the rear wheels as well, because it makes removing the old bar and installing the new one much easier.
The "Executive Sedan"
