Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - 225/40/18 PSI max
View Single Post
Old 08-11-2008, 01:13 AM   #6 (permalink)
darksparkz
2GR FTW
darksparkz's Avatar
View darksparkz's Photo Gallery
"most tires" are OEM tires, so you should follow the door sticker recommendations only if you have the stock tires and wheels on.
As far as the stiffer and shorter sidewall due to his 40 profile tires, the structure of the tire bears its weight on the sidewall more, so a higher tire pressure is required to be able to help the sidewall withstand a bit of the weight of the car.
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
darksparkz is offline   Reply With Quote
