Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - 1991 Celica GT with 3S-GTE swap (already done), a few questions
View Single Post
Old 08-16-2008, 09:46 PM   #9 (permalink)
fredk
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
there is a support bearing on the passenger side drive axle that bolts to the motor, you sound like you left the 4 cyl axles in it along with the trans, if you use a v6 trans the bracket-bearing asy wont fit up to the motor that fits onto the v6 axles and the v6 trans takes v6 axles so the axles are bigger and wont fit into the 4 cyl bracket-bearing asy, you need the 4 cyl bracket with the v6 sized bearing off an alltrac or mr2 turbo
